I had a bad synchro or blocker ring in 3rd gear, so I swapped in a known good transmission, put some new u-joint straps on and went for a spin. There's now a minor shifter vibration under accel/decel above 3k engine rpm. No vibe when declutched. Prop shaft was indexed to the diff yoke pre/post. I tried loosening the rear mount and sliding the trans to the side a touch but no improvement. There is a little more room. I'm running IPSCO shifter, trans x-member, Engergy trans bushing. Throw-out bearing and pilot bushing are in good shape, as is the clutch. Motor mounts are reasonably new OEM and I don't wheel hop the car at all.
I picked up a couple of worm hose clamps to try an external shaft balance, but that would seem unnecessary given that it wasn't vibrating at all before.
Any ideas? I have a race next Fri/Sat and need to sort out this weekend.
