eaks
Hello all, I've had my new to me mamba edition srt-10 for about a month now. It's got about 40k miles and I'm slowing addressing all the small little issues that I've found. I replaced the head unit with a wireless car play plug and play solution and added a backup camera. I made some -10an lines to replace the oil cooler lines that were slightly leaking (just waiting on the orb-an connector and will do an oil change and get this sorted). Also waiting on my order from ipsco for a short shifter, knob lowering kit, couple mounts and a 2" seat lowering kit (I'm 6'4").
I find the soft top latch may have an issue but I'm not sure if this is how they are supposed to operate. When u unlatch the latch the actual hook doesn't seem to completely clear the latch and I sometimes need to use my finger to get it to drop and clear the latch to lower the soft top. When I fold it down the latch seems to sit horizontal and I expect with the latch undone it should be more vertical. It is more of an issue when putting the soft top on and latching I need to pull down the hook to a more vertical position while I try to latch the roof.
It isn't a big deal and I am quite used to it now but I'm sure this isn't how it is supposed to operate and expect something might have broken inside the latch. Any suggestions?
Also if anyone has any links and install pics of spoilers in the soft top srt-10 post some pictures as I am considering doing a spoiler as well.
Thank you everyone
Thank you everyone
