2000_Black_RT10
Loctite is 'anaerobic' in that it sets in the absense of air and not from the heat created by the friction of installation. It also is not to be used in metal to plastic applications. I'm not sure if the carbon fiber resins are 'plastic' or not but I don't think Loctite should be used in this application. But if your not having any issues maybe that's the right thing to do... I dunno.
Screws typically are never threaded directly into carbon fibre, there's a hard point, either an insert made of (anodized) aluminum, steel or delrin, rivnut or floating nut plate on the inside that is embedded into the carbon fibre, inside the part.
Metal screws, either steel, alloy etc.. in carbon fibre will encourage galvanic corrosion and require some type of coating. It would be a very, very poor practice / application if the screw is threaded directly into the carbon fibre material thickness and cutting a thread in carbon fibre is not good, and I highly doubt that they did this. If they did, shame on them.
Anybody have some pics of the threaded hole. You may have to look beyond the carbon fibre material thickness in the hole to see if there is different material that the screw threads into.
