Some Exhaust work on the Gen 4 :)
SRT09
Edmonton
Here are some pics of the header install I did, and custom exhaust I fabricated for my 09.
SRT09
Edmonton
Had to do some customization on the M&M headers as the drivers side O2 **** was welded in the wrong place and casued my O2 sensor to become pinched between the exhaust and block cutting its wires :( Took the manifold back out and tig'd a new **** lower down and replaced the senor.
mikerae
RED DEER ALBERTA CANADA
i just put headers on and had to splice the 02 sensors , they are now giving me grief. Did you have to splice or do you know of a part number that have longer wire length.
i also had melting issues on both sides behind the fender and firewall, the black plastic that is under the fender vents. this only happened on the track and was good while driving normal, i also added the heat shield product from the viper store to prevent higher heat on the side sills. This may have contributed to the build up of head due to restricted air movement.
ctrengine
