Speed with Soft Top
Gen1blk
Phoenix
Curious what is a safe top speed to drive with the soft top on? Will it handle 80-90mph? Might take the car on a trip and need to have it on.
I have run mine up to 120, BUT it depends on what your front latches are. Are they a blade type or the roll pins? If roll pins, stay below 100
G
Gen1blk
Phoenix
My front latches have a handle from the inside that you twist to lock.
Got that, they all do. Look on the business end. What does the other side of the latch look like? Pic?
The early ones had a small roll pin driven thru across the lever shaft. It engaged under a stiff piece of wire in the windshield header receptacle. With too much air pressure at the header, the wires would deflect up, the roll pins would lose contact and the top went sailing.
In my new '93, I hit a hundred or so with the top on a few times. But I was already hearing of failures so I didn't do it very often.
Dan Cragin
LA, CA
The soft top will come off at exactly 147mph. I have confirmed this.
Keeping the front latches tight so there is no air gap between the windshield to and seal is critical.
The is an adjustment if you remove the latch.
Chad Spackman
Chester Springs Pa
Mine has come off at 75. At which point it was never ever used again. Model year 94. Autoform to the rescue. But making a statement about precise speeds is nonsense. Prevailing winds, and gusts, etc. c’mon
Nope, but if you want to guarantee the 100 MPH number, just put 4 strips of 100MPH tape on the top to the front windshield, then it's locked in!!!!
:D
