SNKBYT
Where can you get a spring compressor that will fit the stock Koni shocks to remove the springs to
adjust the dampening?
That hydraulic compressor probably won't work on a Viper (5" minimum spring diameter).
I purchased this manual compressor from Harbor Freight: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=43753 I needed to cut down the hooks about 1/4" to make them fit between the Viper's spring coils. After that, compressing the spring is a 1 minute job with an impact wrench.
"AS RECOMMENDED" where? I think you're making a broad generalization about the instructions that come with two-piece screw type spring compressors that is not accurate. Lacking any specific instructions with the ones I own, I use grease, which works fine.Agree with ab...however, IF those using the screw type use ANTISEIZE on the threads AS RECOMMENDED and there is LESS of a chance of a problem.
OK, I give - where was lubricant mentioned, WD-40 specifically? I don't see anyone saying anything about WD-40.WD-40 is NOT antiseize...and using both WD-40 and an impact wrench is asking for trouble...especially with the $9.00 specials from Harbor Freight.
It might be sufficient to take some strong zip ties and zip-tie the sping to the hooks, or perhaps some hose clamps.Now I see the problem - I think I will need to strip some of the paint off the "hooks". It's pretty thick.
