Squeaky Brakes
Shelby3
liu;g
EBC greens at Greatbreaks.com will cure the squealing and the dust.
garolittle
Augusta, GA
Race cars have racing breaks. End result .... all Vipers squeak (until you install the EBC pads referenced above). Call Jon B. at PartsRack. :usa:
95Viper
Phoenix
Ensure you prep the rotors before installing the Greens or you might still squeak. Prep right = no squeak/dust.
Bluvenm97
AZ, USA
Can someone elaborate on this prep of the rotors? I installed EBC's with new slotted 2pc rotors, and they squeak like hell under light braking, just before stopping. I broke them in per the directions...
Purdue_Boiler_Viper
Indy
My greens squeaked after installation on stock rotors. I did a little prep to knock the corrosion off the rotors with that install. Then I got serious and got the 3M Roloc pads and really prepped the rotors. After the Roloc, the rotors were really cleaned up, and the squeaks were gone.
But, if you have new rotors, Roloc won't help. The only other thing I do is to use Disc Brake Quiet. There are a number of these products out there, spray and glue-like. They dampen the vibrations that cause the squeaks. Sometimes they do the trick.
Good luck.
95Viper
Phoenix
Don't get the new compound EBC Greens if you are looking for low dust. Not like the old ones. I hear Reds are the trick now.
ViperTony
Purdue: Can you elaborate on your Roluc technique? Which grade/grit/size disc did you use? Any tricks I should be aware of if I decide to go the Roluc route on my rotors? Thanks - Tony
Purdue_Boiler_Viper
Indy
I've got a write up somewhere on Roloc. I'll find it and post it.
Here is the 3M name for the product: 3M™ Roloc™ Brake Rotor Surface Conditioning Disc Starter Pack, 01410, 12 per case.
kc651
