Squeaky clutch pedal?
V10SpeedLuvr
Every now and then when I start driving my car (did it a couple times about a month ago, and now has done it the past 2 days) the clutch makes a fairly loud squeaky noise everytime i depress it to change gears. It cuts out after a few miles of driving (I'm assuming once the car has warmed up). The noise is definitly coming from inside the cabin, so its nothing under the hood. I thought it may be temp. related b/c the 1st time it did it, it was pretty cold, but its done it the past 2 days and the temp has been in the 50's. Any ideas?
ViperJohn
Maryland
You need to lubricate the clutch pedal. I had the same noise develop in my O2. Spraying some lubricant on the clutch pedal assembly took care of it.
Randy
Earth?
There was also a known problem with '95 clutch pedal pivot point failure, and the '96 RT might have the same design. The squeak might be a warning that this is close to happening?
Kkustelski
