SneakyPete13
Hello, new owner of a 94 RT/10. Thank you for all the support amply available just looking at various threads. Saw a thread about what to do as soon as somebody gets a Gen 1/2 and did the power steering pump pulley and bracket upgrade (machined Aluminum). Since then I've noticed a squealing starting at a certain RPM (above 1200 or so). At idle and at very low revs there is no squealing whatsoever. The squealing doesn't seem to be increasing in pitch with revs either. Just by hovering over the engine I think it is definitely coming from the serpentine belt. The obvious answers given with "conventional vehicles" are misaligned pulleys, old/worn belt, tensioner issues etc. Before replacing the belt (as the first try), wanted to know if this is normal at all with the billet pulley, or something I should definitely look into immediately. Thank you in advance!
