SRT-10 ABS retrofit kit???
Will
San Mateo, CA USA
With a 60 to 0mph stat of 97 feet is Dodge going to provide a brake retrofit kit for '96 to '00 Vipers?
Just curious....
Will
Just curious....
Will
They will not offer a "kit." However, it *might* be possible to retrofit the system to the Gen2. You would have to use the all-new knuckles to mount the calipers, as they bolt on similar to the StopTech units. It would take some measuring, or someone to pop the knuckles off a Gen3 SRT and see if they will slip into the ball joint sockets of the Gen2 wishbones. Then, you'd have to bump steer the car and see if the geometry is substantially revised as well. I know that the anti-squat and anti-dive geometry is revised (less radical than before) and that the front wishbones will not interchange with a Gen2. The rears at least *look* like they might.
I could do it, but I haven't got the slightest inclination to take my new SRT apart.
