SRT-10 Engine Noise
TUTSGTSR
Engine just started making a loud high frequency wine. Gets louder with RPM and goes up and down with the RPM's. Sounds like its coming from the power steering pump or water pump. Car has 800 miles and runs cool. Local dealer says they will investigate ??? anyone else suffered this as of yet ??
TRAMP 13
Montgomery ,Al
check the bolts that hold the motor in place,my sound came from the motor on the passenger side,the shield was resting against the frame because the bolts had came loose,you could hear it in the cabin area real good.I posted early about my sound and the problems was that the motor bolts had came loose ,you may have the same problems.
SCLSSRT10
My car with 3500 miles has been making the same sound for a couple days. I was at Gingerman over the weekend and had the guys from Autoform listen. They agreed with me saying that the power steering pump is going out. I plan on taking it to the dealer next week for the necessary repairs. If it is anything else I will post a message end of next week.
CHARGER01
