Stainless steel brake lines.....
Qualitywires.com
Louisville, KY
Will I get or notice braking power from this small upgrade?
I have ebc greens on my car now and when I took it to the track last time, I had a hell of a time trying to get my car to slow down...is it the brake pads or is it the lines and the stock calipers I am using?
In order to stop, I had to downshift my car plus braking....
SingleMalt
Well, I've got both the larger calipers in rear as well as the stainless lines, and I can tell you (I did them on separate occasions) each upgrade helped; SS lines sealed the deal. I never lock up a front anymore because of the increased feel. First upgrade you should do: rear calipers.
Mike
mit
Austin, TX USA
Just to clarify. The rear caliper upgrade does not work with a 2001 GTS, right?
I will need new rotors next time I need pads which won't be too long. I am just going to get it done once and for all at that time and get the Stoptech 4 wheel kit.
Is there a more cost effective solution for a 2001? I do think the stock brakes **** even on the street.
Fast Viper Dan
Saratoga, CA, USA
Your EBC Greens are great for the street, but not good enough for the track.
Hisserman is right.
I recommend having a set of pads AND rotors to change back and forth for track and street. What I have found is the material from one pad sticks to the material left behind from the other and you get a bump feeling in the peddle.
ruckdr
Renton, WA USA
SS brake lines a must; especially if you do any track days.
How do they feel? just step on the floor and push hard - the floor does not move - neither does the pedal.
Later,
plumcrazy
ALL OVER
i got the same car with SS lines and EBC greens....I love the feel and it stops better on the road. NOT sure what its like on a track as mine has never been.....YET
sham5430
