Standard Konis are adjustable, I\'ve done it, its good
I asked around quite a few people at VOI and not many knew that the standard Konis are adjustable. I wasn't entirely sure myself, so I decided to find out on my return from VOI. I felt that my 99 GTS was definitely set up on the comfort side of good handling, with a general looseness in corners and an un-nerving wallow especially around the point where the rear end breaks away and grips again. Not confidence inspiring ! The spring rates felt reasonably good for fast road use, but the damping was way too soft, mainly in rebound.
I removed the spring/shock assembly from the car starting at the front, and with a set of spring compressors, removed the spring, then the plastic washer and the rubber bump stop(both split to facilitate fitting and removal). Then by clamping the bottom mounting of the Koni in the vice and fully compressing the shocks travel ( not the vice!) you will be able with a slight turn ( whilst fully compressed ) to feel the internal adjuster engaging. Whilst looking down from the top of the Koni, turning it anticlockwise, whilst still compressed, will reduce the rebound damping and clockwise increases it. There is a total of one and three quarters of a turn adjustment.
Mine were already turned fully anticlockwise ( minimum softest setting ), so I started by increasing the fronts to a half turn clockwise and reinstalling them, A road test showed no appreciable difference.
So out they came again, this time I tried a few different settings on the bench, and its difficult to feel any change until the adjuster is past one full turn clockwise. So I settled on one and a quarter turns all around, front and back, which leaves the Konis noticeably stiffer to fully extend by the very scientific method of standing on the bench above the vice and heaving as hard as I could to extend it.
After re-installing everything and it is a fair bit of work, it took me a full day and a bit of messing about, a roadtest revealed a greatly improved viper, no I'll say that again.... A TRANSFORMED VIPER !! The handling feels as I imagine it was designed to feel, better turn in, less after turn in wallow, much greater precision on the road, (and some of the roads in the UK and Ireland tax viper handling to the maximum). It is actually possible to feel what is happening with the suspension and the feedback from the road surface and tyres is altogether better.
I always knew that Konis were good dampers, and for no outlay, apart from my time, I have enabled them to start doing the job they were intended to do. I am delghted
![bounce.gif](/vca/proxy.php?image=http%3A%2F%2Fvca1.viperclub.org%2Fubb%2Fsmilies%2Fbounce.gif&hash=7adaf23b3b6df740b9091c305a7cf6a8)
![smile.gif](/vca/proxy.php?image=http%3A%2F%2Fvca1.viperclub.org%2Fubb%2Fsmilies%2Fsmile.gif&hash=39a3472a80716f8214b5aeac86724ce0)
![BURNOUT.gif](/vca/proxy.php?image=http%3A%2F%2Fvca1.viperclub.org%2Fubb%2Fsmilies%2FBURNOUT.gif&hash=f7fe300d7dfb42528d987efa8a9fad08)
