Tim
I have just run 12.841 and 110.32 MPH in a 94 RT10 Gen with smooth tubes, K&N’s, and no cat’s. Pilot sports @ 55 psi on the front and 18 psi rear. Every thing else is stock. The motor is an Arrow rebuild on warranty due to shifted sleeves. Car and driver of 3600 pounds. Some traction compound sprayed on the track.
60 ft time of 2.042
Now the track is 2200’ asl, 73 deg f, humidity of 36% with a dew point of 39 f with an altimeter setting of 29.5.
Density altitude works out to 3700 ft asl. Average power loss is 3% per 1000 ft so that’s 11.1% from sea level.
Run the numbers for Hp versus ET gives me 403 @ the flywheel. I add on my 11.1% to give me 447.
Trap speed gives me 453 Hp @ the flywheel. Add my 11.1% puts me over 500 Hp. This I can’t believe.
Can anyone help me out on what’s happening here? I was going to sell the car for a newer one with more power, real windows and air conditioning but maybe I should hang onto this one. This is my 1st time at the track so I could very well be missing something here. I will post the time slip when I can get to a scanner on Tues.
Tim
60 ft time of 2.042
Tim
