Stock SRT10 Rocker Ratio
2002_red_gts
San Diego
What is the stock ratio of the gen 3 (03 and up) Rocker ratio? Ive been told they where 1.73 but ive been doing some research and getting mixed answers saying there 1.7? Does anyone have the answer? I no its not to much of a difference but with my cam that extra .03 puts it right at .600' lift
ssjcreeper
Ohio
1.7 is what I've always understood it to be though in conversation with Jon B recently... I believe he stated it was actually a hair under that but i don't recall what he told me exactly. 1.69 maybe.
2002_red_gts
San Diego
2002_red_gts
San Diego
Did anyone find the answer to this? How could you measure the stock rockers to find out what they are?
ssjcreeper
Ohio
Mike,
I was curious what the ratio was after you posted this and asked around. The answer I got back was also 1.73. Here's a PDF I ran across from Crower when I ordered my new shaft-mount system. First page gives some info on determining rocker ratio.
2002_red_gts
San Diego
Thanks! I'm pretty sure after looking around that there 1.73. Not that it makes a big difference just want to found out thank you for the info
Cape Coral, FL
I have seen everything between 1.7-1.75. The problem is, if the rocker isnt installed when measured, there is a long fulcrum tip to "guess" where the contact point is. I would assume this is the reason for the differences. However, based on what internal info I have seen from SRT over the years, 1.7 appears to be the actual spec.
