georgethedog
The dome light on my mirror will not go off (Gen 1). The only way it will turn off is if I unplug it, which I have. Anyone have any ideas? Thanks. ![dunno :dunno: :dunno:](/vca/styles/default/xenforo/smilies/dunno.gif)
While the above are true, there is also a tiny map-lite button switch on the underside of the mirror.....HARD to see. You can bump it and turn it on...and it STAYS on. It eats a LOT of volts/batteries as it goes unnoticed in daylight.............
Let us know??
I had the same problem and it's because I'm an idiot. You can turn on the dome light manually on the mirror, by opening the door, or by rotating the headlight switch. I was unplugging mine, trying to troubleshoot it, but it turns out when I was at the track and my knee had somehow rotated the headlight switch.
It's dumb/simple, but try that before diving in too much. Good luck!
Glad you found an easy fix, but this thread would have been a lot more fun if you had found that out 'after' you had the door and wiring gutted.![]()
