Supercharger worked out well.....
Viper Fever
Pocatello,Idaho,83201 U.S.A.
Sean I find myself staring at your super charger I was transfixed on the picture for at least 5 minutes thinking-----I want one .How much if any will the super charger raise the engine temp in normal driving and do it yourself install time on your base kit useing stock throttle bodies . keep up the excellant work
Sean Roe
Jacksonville, FL
The Autorotor twin screw makes no noise that you can hear out side of the car and little to none with the hood up.
Installation time is still going to be about 5 hours for most people. 20 bolts and a few connectors to remove the stock intake, then bolt all the new intake and SC parts on, attach the drive support with the upper water pump bolts, put the belt back on, etc.. We can knock one out in 3 hours, without interruptions.
Regarding heat, no major changes. The only thing we've seen is that it heats up faster on the dyno, sitting stationary, with no fan blowing directly into the radiator.
Sean
Vic
Sean- Great job!
How long (ballpark estimate), before its available?
Thanks, hopefull customer
Sean Roe
Jacksonville, FL
Parts are arriving daily. Recent arrivals include polished blowers, 3" smooth tubes, PCV tubes, etc..
Manufacturing is very time consuming and it will unfortunately be late August or into September before we ship the first kits. A lot longer than I ever expected. However, I feel the time has been well spent.
Sean
Keller
Savannah, GA, USA
Sean
I plan on purchasing a Viper this fall and am VERY interested in your kit. I sold my 600 HP Supra and miss the HP dearly and your kit would be the perfect cure (along with a Viper of course).
Up to this point I can't find anything on the pricing of this kit. Can you give us a ballpark estimate?
Awaiting my new toy:
Josh
Sean Roe
Jacksonville, FL
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by GONABITE:
Sean,
Have you installed the rockers and 1'3/4 headers with dyno results yet?
Michael
<HR></BLOCKQUOTE>
Working on the exhaust and waiting on the rockers to arrive. Should be next week or so.
Once we can get enough exhaust out, we'll work on turning up the boost a bit.
Sean
J DAWG
MS
Sean
In the order of most important to least important, what performance mods do you feel is necessary for someone to have in order to achieve peak performance and reliability from your basic SC kit.
John H
Dyess AFB, TX
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by dansauto:
Is this the kit that "blow" into the factory airbox? I have the K&N open type, what do I need to do to make it work?
<HR></BLOCKQUOTE>
You will need to upgrade to a Gen II to make it work.
John H
