Tom and Vipers
We are trying to determine if the following identification tag came from a 96 GTS T56:
The tag is aluminum w/black paint.
It is 3.25" x .75" approximately with a bolt hole at one end.
There are 2 rows of numbers: (I've used periods between numbers to get the approximate spacing since html replaced multiple spaces/tabs with a single space.)
04855045.....L0762
1386-018....A11193
The "8" in the 1st number and the "11193" in the 4th number is twice as wide as the other numerals.
The "A" in the last number is higher than the numbers in that line by approximately 25% of the vertical height of the numbers.
Any help would be appreciated.
Tom
04855045.....L0762
1386-018....A11193
Tom
