Tachometer Signal Input For Datalogging
NVViperTech
Las Vegas,Nevada
I am installing an FJO Racing wideband AFR system and a Racepak GPS data aquisition setup. They are going into an 04 SRT Viper. Where is a convenient place to connect the Tach inputs? Has anyone else put these setups in their cars?
And if so, are there any installation tips anyone can give me?
Thanks.
Phil
Schulmann
Canada
Sorry I can't help you for this signal.
But I am interested in this tool. Can you send me a link ?
vprtech
Los Angeles
Hi , the 03 and up jtec ecu's still have the tach output . You will need to get a pigtail termial (available from any chrysler/dodge dealer) and will have to drill out the back of the pcm connector at pin 31 . I believe it is connector 3 , if the ecu is in the car it would be the connector that is closest to the front of the car . Insert the wire and you have a tach output . Worst case , I can send you a wire , we have them is stock .
- Chris
www.dcperformance.com
wrm92
