Hey folks,
I'm chipping in my $.02 on the Michelin run flats that our SRT-10s come equipped with.
I have read and heard from several sources that the Viper SRT-10 can 'give way without any notice' ...most if not all of these comments were with new cars, presumedly using the run flats.
So, here's my tip:
Run flats are different from other tires and for proper handling they need one thing, SUFFICIENT AIR PRESSURE!
It really is that simple.
I have tracked my SRT-10 twice in the past 30 days. For the first event (the higher speed track) I used 36 pounds at each corner (each tire) COLD PRESSURE ---meaning the air pressure in the tire was 36 pounds after the car had been sitting overnight. I did not have one single experience with the tires getting "greasy" or slipping away with no warning. In fact, I didn't have any tire slippage that wasn't extremely well communicated.
Now, day one at the second event (shorter more technical track -lots of turns, not as high speed) I, at first, ran with 34 pounds at each corner cold. Again, no problem (I did use the first lap to warm up the tires since there are a lot of hard twisties, but, I would have done this with any car using any tire). In the afternoon of the first day (after running twice in the morning) I dropped the pressures to 30 at each corner (cold pressure equivalent). This time it took 4 laps to get the tires hot (6 miles!) and on the second time out I spun with absolutely no warning whatsoever in the first lap! (the tire was quite 'greasy', like I hit an oil patch, but, I didn't of course).
For day two of the second event, I put the cold pressure to 36 at each corner, ran 4 times that day, very hard, no problems, none, tires very predictable.
Previously, on the street I had "weird" sliding motions with the tires...they were at 26 pounds then (cold). This seems to corroborate with the lower pressure I tried at the track.
So, bottom line, run at least 34 pounds cold pressure in the run flats and you should have no 'out of control' experiences with the tires (I would recommend 36 but at 36 you feel a lot more of the road's imperfections, 34 seems to work well and still be sufficient pressure to keep the tire manageable and predictable).
If the dealers would air up the tires there just might be fewer folks going off road on their first trip home...
I know "29" is the factory manual recommended pressure, I completely disagree that that is a safe pressure to use. I just think that's the recommended pressure because it is what gets the best gas mileage and tire wear...
That's my $.02,
J
So, here's my tip:
![thumbs :2tu: :2tu:](/vca/styles/default/xenforo/smilies/2thumbs.gif)
That's my $.02,
J
