prevnine11ownr
If im Buying 19's with pirellis (sp?) These are NON_RUNFLATS ! What do I do about the low-press warning noise and light? Is there a way to disable the code? Thanks
Buy new sensors and have them installed with the new tires / wheels.
OPTIONS:
There are 3 options. Long ago I decided NOT to spill my guts here anymore because I just end up teaching my competition. I welcome your calls.
Simple answer:
Have a Dodge/Jeep/Chrysler Dealer or Viper Days Tech/Vendors TURN IT OFF with a DRB. (Must be turned back on when/if you restore run-flat sensors/tires.
Unfortunately, Removing the chime is not an option, and removing a fuse may casue other problems.
just take the sensors out of ur old wheels...and epoxy them to the new wheels (along wit some strong tape)...i just finished doing it today on my corvette when i put a 19/20 combo on it
My dealer said they could disable the sensors with the DRB, so I just took it in. 1 1/2 hours later and after several sensor relearns (stock tires), they came out and said they can't find out where to make the change in the 2005 software. The shop foreman doesn't believe they can disable it anymore.
Any other solutions???
I have 2 sets of wheels. I put sensors on the other set of wheels too. $39 each sensor (Dodge dealer), I change the wheels back and forth no problem. Jon also told me they would have to be reprogrammed by the dealer, but they don’t.
You do have to be careful not to break the sensors when mounting though, trust me on that one.
Kai, I sell the Smart Tire system. It's the best you can get. I wouldn't dream of running a car without it. It measures tire temp and pressure. No interference with the oem system, as it operates on a totaly different freq.
The complete system with a remote display, is around $250.00 very easy to install.
If you are running non-runflats, this is a must, as you will not know if you have a low tire, or a tire on it's way down till it blows the sidewall out. This nearly wrecked me one late night.
It gives great peace of mind to know what your tire pressure is at any moment, and have a warning system that goes off if the tire falls below a preset pressure.
You can't even give a visual to the tires before taking off. 10lbs, looks the same as 30lbs, and the car really drives somewhat ok.
Let me know if you want this system. I can get it out to you right away.
Skip White
Kai, the complete system sells for around $250.00 and the pressure alarm system is totaly variable.
Funny thing is I never had an audible alarm on the oem system, and it seems a good audio sound man can disable the oem system easily.
You will like the temp sensors in the system. It is very accuarate, and very important when running low pressures.
Skip White
