TRACKDAY
Over the last several months of track use, I've noticed all four tires continue to spin on the rims during hard braking and acceleration. As a result, all four tires / rims end up out of balance. This is definitely a bad thing to happen while on track For your background knowledge, I always mark the tire with a piece of chalk in line with the valve stem and then note how far off the chalk mark is when I return to the pits.
In the past, I used Michelin Pilot Sport Cup tires and didn't experience much in the way of tire / rim slippage. Several months ago, I upgraded to Hoosier R7's and have experienced ALOT of tire / rim slippage during track use (presumably due to it being a more aggressive race compound, as well as a full slick which produces more grip than the Michelin PSC's).
Has anyone else experienced this problem? If so, what was your solution?
I'm getting very tired of constantly re-balancing my tires / rims
In researching the problem, I saw there are tire / rim kits which prevent the tire from spinning on the rim; however, they are for drag radials not road racing tires / track cars.
I also discovered that Chevrolet, in developing the Z28 for track use, experienced the same problem. Their solution was to media blast the inner lip of the rim where the tire bead makes contact with the rim.
This sounds like a logical solution and I'm leaning towards having this done.
Thanks for any input
