wastntim
Some quick questions for tracking ps2's:
1) When using ps2's on the track, what type of break in should be done, if any, prior to tracking the tires?
2) How many heat cycles should you limit a set to?
3) Is it heat cycles that really matter or tread wear?
4) Do people generally run the ps2's with more air pressure than they used to with the regular pilot sports due to the soft tread?
