Robert1994
As my 5th gear is giving me problems, I obtained another transmission (used) to install in my car.
Reading the '94 Viper shop manual, it says that the
transmission should have the VIN# stamped onto a pad on the
left rear of the transmission.
I checked the unit I am going to install, and there are no
numbers on the pad at all. There is however a red metal tag
that has been attached with epoxy onto the right side of the tail shaft.
The numbers on it don't appear to be prod dates or VIN numbers.
Is the unit I am installing already a replacement trans ?
Any info would be greatly appreciated.
