What is the procedure for resetting the PCM?
many threads on this.
Tators recommended is
1)disconnect pos. side of battery and ground the cable for 30 secs. Make sure it's a good spot (I check with voltmeter). This dumps memory and computer can "re-learn". reconnect pos. cable to battery
***DO NOT disconnect at jump post
2)turn key to "on" position and push throttle to floor 3 x's. Turn key to off. This re-sets throttle position sensor.
3) start car, and let it "re-learn" idle positions. Let it die if you have to. Don't try to save it.
4) driving will start new LT/STFT's.
Hope this helps.
Now, everyone can start correcting me and/or adding to procedure that I have forgotten.
