Turn Signal Indicator Not Lighting
miniguy
‘98 GTS. Right turn signal indicator arrow doesn’t light up. Flasher sounds normal and all exterior turn signal lights work fine. Seems like the bulb for the right arrow has failed. How difficult is it to replace the bulb?
Suregrip391
Niagara Falls
Interesting, will be following….I thought mine was out also, same side, but if you look very closely, it still blinks VERY dim. Was going to try changing the bulb but was unsure where to begin.
It's been a while since I pulled the dash on my mom's 94 to paint it, so can't recall how difficult of a job it was. Thinking you'd probably have to do similar to get to any instrument cluster bulbs, but I suppose there's always a chance you might be able to reach up behind it from the pedals, assuming you can contort yourself in there to begin with. Though I also don't know how similar or not the gen 2 is to the gen 1 when it comes to the dash. I haven't really played around with any gen 2's in all the work I've done.
No members online now.
TheHunter
