Under Hood Viper Logo Print on Insulation
Vanquish
Freeport, Long Island, NY
Guys,
I have noticed that a few of you guys have the under side of your hoods viper logo painted the same color as the car. Is that a sticker that attached to the underside or do you paint it yourselves?
Regards,
BR
Kurt 97 GTS
Dallas, TX
Just a quick question regarding the technique of using spray paint by putting it into a jar and then brushing it on (people from previous thread did this). How does this help minimize brush marks? I know that the spray paint is thinner, but wouldn't it be better (though harder) to just spray both colors onto the pad? Thanks for the information!!
jimandela
Western New York, USA
kurt,
brush marks were not a problem.
too my time did it myself. check the thread above.
lots of details...
best wishes
JIM
ACELLR8
Harrisburg, PA
Mine is holding up great!! No cracks and it to clean it I just take a rag with Mequires quick detail sprayed on it and wipe the dust off.
KenH
Portland, OR, USA
I did mine about 8 months and 7,000 miles ago using Home Depot paint and a paint brush and it still looks new. Haven't even had to clean it.
--- Ken
Snake Bitten
Southern Kalifornia
HOW I PAINTED MY PAD?...Order up the plastic clips from Mopar...you will need 19, but they come in bags of 10...so get two bags...order them ahead of time from Chuck Tator (914-763-3136)...You will break most of your old clips removing the pad...For all of the spray paints, I used engine block spray paint, but any high temp oil based spray paint will work...
1. With the pad off...give her a once over with SEMI-gloss black...just enough to get the pad uniformly black, doesn't take much...may not be necassary if your car is new, but if the pad is showing white spots from the car wash, this is an easy trick to make the pad look new!
2. With masking tape and an exacto (razor) knife, mask off the whole outside edge of the emblem...and the rest of the hood pad, so that all you can see is the emblem...
3. Apply four coats of primer, allow two hours drying time in between coats...Allow to dry 24 hrs.
4. Mask off the Low portions of the emblem, apply however many coats looks good, at least three...two hours between each coat.
5. Allow to dry 24 hrs after last coat before removing masking tape.
6. Mask off the High portions of the emblem, apply however many coats looks good, at least three...two hours between each coat.
7. Allow to dry 24 hrs after last coat before removing masking tape.
8. Now your emblem is painted, but the hood pad is still masked...APPLY three to four coats of clear or as many as you want...how shiny do ya want it?! Allow to dry for 24 - 36 hours...
9. Peal the remaining mask.
10. I then took a brand new black Sharpie, and went around the lines inside the emblem, to kind of separate things...but be careful...you cannot see this unless you get right up on the emblem, but it makes for a nice effect...could you see this in my pic? People only notice if I tell them...optical illusion, but really adds depth...and covers any minor, and I mean minor, masking errors...you can always touch areas up by spraying into a cup and using a tiny brush...
11. Re-install pad!
12. Masking is the key, use the 3M blue masking tape (Home Depot), and use real short pieces overlapped to get around the curves, and use the razor knife to make them perfect...
13. PATIENCE, PATIENCE, PATIENCE...especially in masking...and take your time with the coats of paint, you can alway spray another coat if the one you just laid didn't cover...so no need to lay any one coat on too thick...
14. POST PICS WHEN YOU ARE DONE!
ViperGear
