Upgrade to 708 Lumpy Cam or aftermarket?
jk
Richardson, TX USA
So the cam, can be put in by jacking motor up?
I put the cam in by releasing the motor mounts and angling the motor up slightly. Had to remove the cross-member (which requires a jack and the weight of the car to take off the tension on the cross-member), and remove the bolts from the AC condensor and lean it forward as much as possible (did not have to break the seal on the AC system). That gave me about an inch of room to slide the cam out and back in.
VIPER BAZ UK
ENGLAND
Thats how mine was done also.............
Raymond
