UtahViper @ 2100 FT = 10.47 @ 132 On BFG's...
Larry Macedo
Sanford, FL
UtahViper @ 2100 FT = 10.47 @ 132 On BFG\'s...
with a short time 0f 1.52!
Congrats Todd! Wish I were there with you guys, maybe next time. BTW, it was after 1:00 AM when you called my house this morning. That's OK though, Ward was ringing my doorbell last night around 11:00 PM. I owe you both...
L
Larry Macedo
Sanford, FL
Re: UtahViper @ 2100 FT = 10.47 @ 132 On BFG\'s...
Additionally, I believe this is the fastest ET for BFG's to date? If it is, way to go Todd!
Anyone know the fastest ET for Michelin Pilot Sports? Ward ran a 10.82 in Norwalk, OH, last month.
Sam 01 RT10
Las Vegas NV
Awesome! I wish I could have been there tonight, but alas, no sitter for the little ones.
utahviper
Utah
It is late so I will post the time slip numbers.
LVMS 2100FT elevation
Temp 74
Relative humidity 70
Absolute barometer 29.32
60' 1.525
330' 4.354
1/8 6.720
MPH 106.66
1000 8.767
1/4 10.474
MPH 132.57
That track hooked hard! Another run I got a 1.547 60' time. I was able to launch at 3500rpm with no wheel spin.
It is late.
Cudaman
USA
Congrats on the impressive 60ft's and low ET's on the BFGs in the mountains !!!
Cudaman :usa:
J DAWG
MS
Way to go. It seems everyday you have a new best time and that's how it should be. Keep enjoying the car. :cool:
CHAD
Sarasota, FL
Larry, I thought I saw a 10.5 on Pilots here, not too long ago. Could be wrong.
That 10.4 is a great time, especially at altitude. Great job Utah.
Chad
Cudaman
USA
Chad
Chad... that was my Pilot time aprox 3 weeks ago in Norwalk, Ohio, (another Macedo tuned Roe S/C).
Cudaman :usa:
CHAD
Sarasota, FL
You need to tell Larry. He thinks you ran an eighty.
Chad
Cudaman
USA
Chad it was a 10.809 with a 1.67 60 ft on Pilots..... sorry my fault....ran a 10.5 on ET's and skinny's with an experimental intercooler piece of junk...slowed down the car.
Cudaman :usa:
Back to UtahViper thread......We need to get you to lower elevations to see how much lower ET's you can achieve.
on I-75 30 miles north of Tampa going to see Gators play
treynor
Redwood City, CA
Sweet - that is an amazing time on radials! A run in cooler weather at sea level would probably put you in the upper 130s...
Now you get to update your .sig again :)
Tom Welch
Blairsville, Georgia
10.80 on my video a few years and a couple hundred HP ago, been 10.60's on Pilots back when just had exhaust and 150 shot (Friday Nite Test and Tune at Orlando, 1999). Remember, as power increases it becomes more and more difficult to put it to the ground for a gain in performance.......especially without chassis modifications. Good time Ward!
Also,
I thought there was a Texas fello...might have been David [******]...claiming 10.40's on Pilots driving someones Viper.????
Tom
L
Larry Macedo
Sanford, FL
Tom,
I'm not up to speed on what records are currently valid because I spent most of mine time road racing Vs drag racing. Congrats on your past times! If it were back in 99, did you have MXX3 Pilots or Pilot Sports? The MXX3 was a better drag racing tire as I'm sure you're aware. Congrats on your 9 second passes in Columbus, BTW!
Tom Welch
Larry,
For the record, I don't keep track of the Pilot times either and have not tried to go fast(Quick) on them as there is no real reason to do so. I have always used Mxx3 on 17" rims. The new BFG 18" tires are the gig, taking the front spot from Khumos and Nitto 555R's.....from what I've seen anyway. Unfortunately, I don't own any of the above.
Tom
1TONY1
Dalton Ga. (Chatt. Tn.)
Awesome runs Utah !! Congrats.......come on down off the hills with some et streets.
ViperGear
