vec 1 wiring installation question
ACELLR8
Harrisburg, PA
trying to install the Vec 1 in my 95 RT-10 and it appears the pcm wire colors and pin numbers are different then what is in the installion manual.
Maybe the installion manual is made for a Gen 2...can anyone who installed the VEC 1 on a gen one...can you tell what pin numbers and wire colors to install the following wires on:
orange wire
brown wire
purple and green together
These are the wire colors comming from the Vec 1 to the PCM
Thanks Ed
SSNAKE
Belleville, IL US
ORANGE - BLACK W/ GREEN STRIPE
BROWN - BLACK W/ BLUE STRIPE
PURPLE -> TO GREEN WIRE W/ RED STRIPE (toward pcm)
GREEN - GREEN WIRE W/ RED STRIPE (going toward engine)
I have your similar mods, what was your peak hp & torque in the dyno graph?
Thank You
AndyR
Cincinnati
Ed, I'm doing the exact same on my 93 right now. Sean Roe sent me the proper pin connections for the Gen 1. Here they are!
A
ACELLR8
Harrisburg, PA
Thank You
Thanks for the pin out help. Here is two dyno sheets before and after motor work. I got about 80 RWHP N/A doing the motor work. I am hoping to fatten my car up some with the VEC 1, as you can see it is very lean.
What was your HP #'s with the mods you have? I did not do the 1.7 ratio roller rockers, and should have.
Before (Stock, except smooth tubes, K&Ns and catback)
After heads, cam, and Edelbrock Long tube headers.
A
ACELLR8
Harrisburg, PA
Andy,
Thanks for the great wiring Diagram. I printed it out to add to my manual.
Can't wait to get home and get this install finished and see how it works!!!
Please let me know the results of the VEC 1 on your car.
Thanks,
Ed
