Wanted water pump 2000 Gen-2 Viper
Anthonyviper
Dubuque Ia
Look where to find a rebuild/new aftermarket Gen 2 water pump or any ideas how to fix the one I have.
5635423506
lane_viper
Tennessee
Someone mentioned the guts out of a Gen 1 pump can be used to rebuild Gen 2s.
Can anyone confirm this? And how would one do this?
Would be good to know going forward in the future as these may continue to be hard to get.
Bill W
Greenville, SC
This is what the Havik webpage says:
Water pump, 1996 – 2002, Dodge Viper​
$1,000.00
The factory impeller is made from plastic, and is known to crack. Upgrade your water pump with our Reman water pump, made with an aluminum impeller design. This kit includes a water pump gasket.
We require a core return with this purchase. A $400 refund will be issued once your old core is received.
Please call to order: (484) 274 – 3037
lane_viper
Tennessee
GTS Dean, Anyway you could elaborate on the rebuild process?
I will take a general swing,
1, press/remove the impeller and shaft
2. remove bearings/seals
3.remove same from donor pump
4. insert bearings seals
5. replace shaft and press/install impeller
I'm just looking for any gotchas on the process as I have a used gen 2 pump from when I replaced mine and am willing to try a rebuild and do a writeup.
Thanks.
If you want to send me your pump, I will rebuild for $500. Covers Shipping both ways.
lane_viper
Tennessee
Looking at options right now, I really appreciate the offer. Not an immediate need right now as this is an old used pump I replaced. Nothing wrong with the one on the GTS right now.
bmillionaire
