What BHP with mods???
VIPER BAZ UK
ENGLAND
1994 RT/10 with
2000 headers
arrow 1.7 roller rockers+pushrods
arrow valve springs
sean roe side exhaust with HF cats
K/N+smooth tubes
180 thermostat
mopar plug wires
Mopar performance bigger valves
Thanks...........
VIPER BAZ UK
ENGLAND
once it has all been fitted parts only turned up today....
thought it would of been more than that?
is that RWHP?
VIPER BAZ UK
ENGLAND
These are the valve sizes..
Oversize intake valve 2.20 dia. Stainless steel
Oversize exhaust valve 1.60 dia. Stainless steel
Cudaman
USA
560-585 ...... :2tu: with the help of a Roe Gen 1 S/C.
Sorry just trying to make you feel a little better.
Cudaman :usa:
Vipermed 97.01
Tampa Fl. USA
If you are only putting "bigger valves" in stock heads other than springs without any port work unfortunately there is little if anything to be gained.Bigger is not always better especially if the path of flow has not changed.You may want to seriously consider working with the heads before you assemble.
VIPER BAZ UK
ENGLAND
Vipermed
What would you recomend on the heads port matching to the inlet manifold and polishing ??
open for sujestions...
BAZ
jp
Umea, Sweden.
Baz,
The most important work on the heads is in the area just before the guides and down to the seats. If you design that area correctly and still go with stock valves will you notice signinficant power gains. In my opinion is a 2.20 Valve over the top.
You will gain almost nothing on port match, the match is very good from factory. (dont polish)
And...remember that the camshaft is what makes the snake bite...
