Pryme
I need new air filters anyway and was thinking I should ditch the stock set up for a cold air intake set-up.
The car has smooth tubes but I THINK its stock otherwise as far as the cai goes.
What do you guys recommend for the gen 1's?
I was told some **** hot air from the radiator and there are good ones that **** in front of it?
I am new to Vipers so go easy on me ha. thanks.
ON A SIDE NOTE:
Has anyone put an amp in there car? did you run the power wire to the terminal under the hood or right to the battery?
the run would be much shorter to the battery I was thinking.
ON A SIDE NOTE:
