okloneranger
- Joined
- Apr 16, 2007
- Posts
- 427
- Reaction score
- 0
Right now I'm taking a break from my annual clean up under the Viper. I like to do this so that I can possibly head off problems that might be covered up under dirt and grease. Anyway. on both sides if the main frame rails just aft of the front A frames is a section of plastic on the bottom fo the rails. This plastic also covers a couple of holes in the rails. It feels like there is some kind of 'gel' inside the frame rails that this plastic seals in. What's the deal? I've noticed these before when cleaning up, but this time thought I'd ask for an explaination. Also, whoever factory welded the frame never heard of splatter guard, and also mig welded it on the 'cold' side. Another welder will know what I'm talking about. If you inspect your frame and there are alot of rough spots on the metal(like grains of sand or bigger) that's weld splatter that stuck to the frame when they welded it. If they didn't apply splatter guard to the frame before welding, or even knock the splatter off before painting, that's what you have. A cold weld looks rough. It is cold because the guy welding it had the machine turned down lower than it should have been and the weld is not as hot and doesn't ********* as deep as it should. A hotter weld will smooth out and just look better, and be stronger. a cold weld 'bunches up' and looks and feels rougher. Anyone know where they had the frames done when they manufactured the cars? I'm sure it's plenty strong enough, but, I'm still keeping my eye on it.
