What Gen 2 Motor Gear box fit Gen 1
R
RTIO
Austraila
Have asked snake if there new flywheel will fit my gen 1 .they have a new steel flywheel
That is lighter than the aluminum flywheel that is out there today.
Dear Daren,
   The aluminum flywheel is as much as any company I know of has done
for the clutch portion of your car. Truthfully, due to the low number of GEN
1 Vipers (which is declining each year), do not expect anyone to make
something special. If you had a GEN 2 or 3 car that would be different, due
to all the race engineering that was developed on/for them.
Thank You,
Kurtis Anderson
RedEnuf93
Lancaster, PA
You can buy many different light weight flywheels for Gen 1 today, just check with vendors or Flea-bay. (Fidanca, Clutchmaster, McLeod, Spec to name few you can find in 3 minutes.)
Mine is 17lbs, which is 10lbs lighter than stock. I have about 800lbs TQ, and the stock clutch is fine for 600Hp and that amount of TQ. You can of course overkill anything.
John21
