Re: What is involved when you \"nut & bolt\" a viper before tracking it?
Along with checking the "nuts and bolts", I would change the oil and brake fluid before and after track session. Check and recheck the power steering cap, fires have been started from a loosened cap. I think bringing a torque wrench to check the lug nuts (90 ft-lbs.) in between sessions is very important. Bring an air pressure gauge too and check the tires. You may need to bleed off any excess pressure as your tires run hotter. If you have the stock battery (Mopar), there's a possibility that the acid may start puking and run down the lower frame. I would just wrap a 'sock' over it for now until it's time for a new battery, then you can consider an Optima or some other sealed type, I run an AC Delco Grp 75. Check your brake pads. A lot of guys go with Brakeman 3s. If you're concerned about road debris getting kicked-up, then get a front bra and tape the headlights.
Hope this helps.
