Paul is right on, as the variables listed, even down to driver style, can affect the range.
I would start cold at around 30 in the rear and do about 3-4 lbs higher in the front --- easy way to get some of the push out with the 275s up front.
Alignment , track surface , ambient air temp, so many things affect the outcome , but check after the runs and also use the old fashioned method of seeing how far down the sidewall the tire is wearing.
No real easy answer as there will be many factors to consider. Use a comfortable starting point, and hopefully when you are at the track there will be a more experienced Viper driver there that can give you some advice or assistance ---- fun often to work with fellow Viper track guys as you may find different approaches and one may fit your experience/driving technique better than others.
