What other tires can fit on the Gen V?
ViperSmith
Tysons Corner, VA
With the rears being 355, there are only two sets of tires out there that fit. Are 345's safe to run on the car? I assume as the year progresses more will become available, but also price is a bit - uh high at the moment.
Voice of Reason
Morton, IL
I'm hoping Michelin comes out with some tires for us. Because I noticed the same thing, 345 is as big as they go right now. I haven't compared the actual tire size of a 345 PSS vs a 355 Corsa, not all sizes are created equal.
V
ViperSmith
Tysons Corner, VA
Yeah. $2100 for the cheapest set with 355 is a bit - uh expensive.
Jack B
NE Ohio
I am goimg to put 345's on my car. The fronts are strange in that they only 25" dia. Does anyone want my corsa's. I have a set of hoosiers, therefore, won't need them.
Nine Ball
Houston, TX
I'll be putting 345 rears on my car. 1cm width isn't noticeable. Up front, I'll probably stay 295 wide, but I think a 305 will fit no problem. Michelin Pilot Super Sport has good sizes for the 295 and 345. Front tire is in the 26" tall range, rear is 27-28" range.
Tony
Jack B
NE Ohio
Keep in mind the oem front is 25" dia. The rears lists at 27.4, however, I measured them on the car and they were only 26.75, I will have to measure them when they are off the car.
Tony
