what rockers, headers 97 gts plus power gain
nismobrown
wales, GB
i have a 97 gts 9,000 miles
hi flow cats
3" corsa catback
k and n panel filter
smooth tubes.
any ideas what are the best headers to go for, i had bellanger on my last 99 gts but there might be better ones out there ?
also roller rockers . i need to know what are the best ones out there for power gain without having to mill the head or similar yet i do not want to end up with anything that sounds louder on the motor than stock.
with the above done approx how much power will the car make,
thanks!
uvbnbit
Kingston Springs, TN
Depends on how much you want to spend.
Harland Sharps w/ rods are about $700?? good for about 20-25hp
Headers are good for another 15-20hp.
I'm sure others will reply too.
mbccenter
Legacy Supporting Vendor
Forest Lake, MN
Harland sharps work well on stock heads but I would not use them when you get into higher spring rates. M and M Perfornace is a sponsor here and has your headers in stock ready to ship.
plumcrazy
ALL OVER
+1 for M&M headers.
SEARCH FEATURE
Almost every question you can think of has already been asked and answered! In some cases, the information may be out of date and a new thread will be needed, but in many cases, an answer to your question may be under 10 seconds away!
The VCA Web Forums has a search feature very similar to web search engines like Google. By typing in a few words, it will search all old posts since the website was created to find words matching what you typed in. Be mindful though, the more words you type the fewer results you will get as it will try to find posts only with all of the words you types. In saying that as well, by using words like “The” and “It” you will get hundreds if not thousands of threads. I might suggest sticking to main words. Also try to avoid year specific searches. It will block out a lot of good info. For example:
“What is the best exhaust system for my 2006”
It might be better as:
“best exhaust”
To do a search, click on Search located in the center of the Directional Information Toolbar. If you are wanting a quick overall search, just type in the words in the search box. For this example, we will go with an Advanced Search as you can further clarify your search parameters.
Once you have clicked on Search, click Advanced Search located under the Quick Search field.
Type in the key words you want to search for. Once you have typed in your key words, click on the drop down arrow on the Search All Open Forums tab located on the lower right side of the Search page if you would like to clarify your search. Choose a specific forums you would like the question searched under. In some cases this is not needed but if you are wanting the best exhaust for your 2008, you will not want the threads from the 1992 cars. This feature helps to cut down on the amount of non-applicable information that will be presented to you. Do remember though, by selecting the one section you are narrowing down the number of places the search will look. If there was a thread in the Racing section, and you only selected the SRT section, you will not see that information. This menu can be useful if used correctly.
Once complete, click Search and see your answers! Feel free to play, there is no limit to the amount of searches you can do!
Glen97
Valley Springs, CA
I also have a 97 GTS. A few months ago I installed a set of Bad Boyzz Garage American Racing Headers also a site sponsor. They are a 2 part header. I dont have any HP numbers but you can sure feel it. Rockers no help that's my next mod.
dave6666
Jessel or wait until you can afford them. As far as headers go I have Belangers and no complaints.
You have to remember, when you ask which brand of part to buy, you're basically starting a poll. Of what everyone has. Which more than likely they'd buy them again and tell you to get them too.
Another thing is that you'd be hard pressed to find anyone that has an organized list of all the headers with a before and after dyno on each one.
Your best bet is to look at the different designs from a mechanical installation standpoint and factor in the price to reach a decision.
Twister
I put harland Sharps on my 99 rt10 and went from 428 rwhp (smooth tubes/KN air intake/no cats) to 440 on the same dyno..Good mod
King RT10
Florida,
Headers on my 1999 Roe S/C car yielded little Hp on the dyno.
Stock are pretty efficient, with high flow cats!
Vic
Twisted logic. (Hah ha, just kidding! Actually some pretty lucid stuff right there!)
CLGPerformance
