05 SRT10 T56 to TR-6060 Trans swap what to expect
FSAconcepts
Claremore
This is for my 05 convertible. Is there anything I’ll run into that I’ll need to change over when swapping from the T56 to the Tr6060 that was in a gen 5 I’ve heard may need a new Yolk ? Will I run into any other problems either under the car or inside with the shift or center console? Anything at all I should Think of my or prepare for ?
Old School
North Alabama
I’ve done it, new yoke and a spacer under the throw bearing to bring it back to where it was. Might work without it, but I didn’t chance it.
Also an excellent time to put a shifter in, much easier when it’s sitting on the garage floor then up in the car. And a good time to go ahead and put a clutch in.
You put the spacer under the Slave cyl? Stock clutch *****, so nearly any else would be better.
Old School
North Alabama
Probably has to do with the gen 4 being dual disk if I remember correctly, so would make sense that there is more room built into the bellhousing for it and the slave would sit a little bit further back. The Viper style slave cylinders are known to have a pretty long stroke though, so probably not a big deal. I have a T56 in my 67 Dart and have run it with and without a 3/8" or so spacer and it worked fine either way. They are self adjusting within the range of travel they have, but never hurts to try to optimize it to have as much as possible available to account for clutch wear over time.
And the stock clutch in the Gen 3 is just fine, not sure what others might be getting at. I ran mine for ~100k miles if I remember right and put a stock spec Luk back in. So far it seems to hold the extra power my cam puts down just fine, though I do wish it didn't have such a long pedal throw. That's my only real gripe with it.
FSAconcepts
FSAconcepts
Claremore
funny thing (old school) I had just installed an IPSCO shifter 2 months ago before I knew I was going to be doing this. Yea I am thinking about the clutch also.
FSAconcepts
FSAconcepts
Claremore
Yep, stock clutch. The GEN4 has a different clutch flywheel set up.
Measuring from the bell housing to block mating surface to the throw out bearing mounting surface showed .125” more with the TR 6060. I used this spacer.
https://www.tickperformance.com/slave-cylinder-shim-113/
you have a Yoke recommendation or one that you used ? did you just swap to a gen4 or 5 ? thanks for the help on the shim man just bought that. shipping cost more than the shim damn near.
Old School
North Alabama
My trans came with a G4 driveshaft, and I just used it. I also replaced the slave cylinder.
FSAconcepts
FSAconcepts
Claremore
well mine was supposed to but suddenly he couldn't find it allegedly. So unless there is a reason to swap to a gen4 or gen4 I may just use my g3 one and find a different yoke. I got that shim yesterday just in case. Appreciate that tip. Ill likely stick with my slave cylinder. I cant decide though whether or not to swap to an aftermarket clutch and lightweight fly wheel or not.
What do you use the car for? Generally speaking a lightweight flywheel is more of a road racing thing and could make driving around town less fun. Granted our cars make enough torque at low rpm that it's maybe not as big of an issue, but I have heard that they can cause issues with some stock PCMs because they accelerate fast enough to trip misfire monitors.
FSAconcepts
FSAconcepts
Claremore
I believe the rear yoke is all there is.
can I just get a yoke adapter without having to by an entire new driveshaft ? I can get a spicer 1-1/16" yoke adapter drive shaft flange yoke for $47 as opposed to a $300 or more driveshaft?
Old School
North Alabama
The driveshafts are identical, so a new yoke would work, but driveshafts are usually balanced as an assembly including the yoke.
Also, the shop manual states that the u-joint straps on the rear axle need to be replaced. If you purchase a strap kit, be aware that the bolts used are metric, while most strap kits come with SAE bolts.
I put a light flywheel on my car at about 17,000 miles. It helped my heel-toe downshifting quite a lot. I also noticed it to be much more sensitive in stop/go driving, particularly in freeway traffic because of less flywheel inertia. 25 years and 25k miles later, it doesn't bother me in the slightest. Still running the same clutch, disc and steel intertia ring on the assembly with at least 5k track miles on it.
FSAconcepts
FSAconcepts
Claremore
So If I were to swap clutch would I still get one based on the gen3 T56 or the gen4/5 Tr6060. Assuming flywheel still be based on 05 gen 3 ?
CLGPerformance
