ViperNM
Sapphire ACR has these goodies?:
Smooth Tubes, B&B Long tube Headers, Roe Racing Custom collectors with hi flow cats, Corsa Exhaust
Harland Sharp 1.7 ratio Roller Rockers, Harland Sharp push rods, guides, lifters, Roe Racing Valve Springs
Roe Racing VEC2 Engine control module – Fuel and Timing only, MS Recalibrated Dodge Factory ECU – Turn off all OBD II functions that effect tuning
MSD 8.5 mm Plug wires and Bosch Platinum Plugs
3.55 differential gear with new factory LSD and speedo calibration module
Big Brembo / Gran Turismo brakes front 14” and rear 13”. Floating Brembo Rotors with aluminum hats
Michelin Pilot Sport Cup 295/35/18 Front and 345/40/18 Rears
Dynamic Suspension Coil Over’s (Factory Race Shock) for GT-2 car, rebuilt at about 10,000 mile by Carl Hass Automotive in Illinois (car has 14,000 currently)
Centerforce Dual friction clutch with centrifugal assist weights
Fidanza Aluminum Flywheel
Fluidyne Aluminum 3 Core Radiator, Roe Racing Front Bumper Fascia Cooling Ducts for radiator, Roe Racing Adjustable Radiator fan control module and 170 Degree Thermostat
Le Mans GT-2 rear wing
I'm thinking heads and cam as it seems the previous owner was going in this direction and probably the least expense. Heads, cam and pushrods, and a tune ought to give me 530-550 RWHP.
The other option is a Paxton at 5-6psi which in this case, I think is probably more expensive. Normally NA is much more expensive but I don't think so in this case.
By far, the brake upgrade is the best upgrade the car has.
So whadya think? Go the next level with heads/cam or a bolt-on Paxton?
Oh yeah - my budget. $5K - $10K.
