Wheel hop ????
Mopar-man
Long Island N.Y.
I have a 2006 viper srt, the problem I had yesterday I took the car out & when I got on it from a roll it was fine till I hit about 4500 rpm then everything got violent ( everything shaking violently) the car is very low milage, never abused. Could it be the original runflat tires?
Scott Mannny
Your very lucky you didn't find yourself in a ditch or into someone else!!! Please change your tires. The same thing happen to me a couple of years ago. Getting new tires
is alot cheaper than replacing a car or paying a hospital bill.
chesapeake07
+1
An absolute requirement.
ViperGeorge
Greenwood Village, CO
Sorry, but I never heard of tires causing a vibration only above 4500 rpms. Was the shaking RPM related or vehicle speed related? If the former I would think the engine or trans is the issue. If the later I would think rear wheel bearings or half shafts. Did the shaking stop if you put the clutch in? Did it shake in any gear when the engine hit 4500 rpms? If it did I would say engine or input to trans.
04MambaNYC
Brooklyn, NY
He is getting normal wheel hop, I get wheel hop on PS2 tires when its cold out in first gear too. Its just a lot of power with little traction thats all.
bmw2nv2000
Adamsville, TN
While tires have alot to do with wheel hop. Slap on a new set of tires and a set of motons and say bye bye to wheel hop. My 08 with good PS2's would still wheel hop even when warmed up until I installed Motons. Absolutely no more wheel hop!!
Allan
La Junta Colorado 81050
Cold tires+cold road surface+heavy right foot = wheel hop almost every time. Continue this and you'll be buying a new rear diff. -don't ask how I know. When these cars wheel hop, it's like hitting the spider gears with a jack hammer!
FastZilla
San Antonio, TX
Wheel hop is mainly a product of IRS and suspension. Tire type & condition amplify this. The Sport Cups are real bad until they warm up. This is the reason many drag only terminator Mustangs convert to solid rear axles or install 2x4 blocks in the suspension effectively prohibiting any travel. Stiffer suspension settings (Motons, K&W, Penske, etc) on the shocks will help reduce this.
Allan is very correct about strain on the drive train, the stickier the surface and the colder your tires the harder the hop. Look at ART's video's on the Tube of their last TX Mile run where the boost cut hit 3 times breaking 5th.
Regarding heat up time on run flats - they take forever to warm up (2 hard laps on the track). Then when they do they retain so much heat and never cool down and become very greasy (after 5-7 laps they are over heated). They will take 30 minutes or more of sitting in the paddock to "cool down".
ulllose
Brunswick, Ohio
Normal!!!!!!!!!!
I've changed my tires.....still wheel hop
I've changed wheels and tires ....still wheel hop
I've changed my trans mount...still wheel hop
I've changed my suspension (kw's).....still wheel hop
Sum it up,,,,,I still have wheel hop! Maybe not as bad but it will all depend on temps, pavement conditions, etc like others have mentioned. It's the car!
Atom
