'Wheezing' Sound Coming from the engine
ViperTony
\'Wheezing\' Sound Coming from the engine
Hi Everyone,
Just got my 2001 RT/10 and it's been a blast to drive around. I recently added K&N air filters and induction tubes from Snakeoyl products. I've noticed a 'wheezing' sound coming from the engine under hard throttling conditions. Performance does not seem affected and other than annoying 'wheezing' from time to time. I want to make certain I'm not damaging the engine in any way. I'm a ****** Viper owner :)
I don't remember if this 'wheezing' existed prior to these changes other than the normal sound of air rushing through the intake, which is now much more noticeable and sounds whicked. I checked the air intake box to make certain it's seated properly and that the filters are positioned correctly. The tubes are on nice and tight, no loose connections anywhere. Just wondering if this is normal. Any ideas?
Thanks.
- Tony
ViperTony
Re: \'Wheezing\' Sound Coming from the engine
:) more like happy whistling!
BLWNV10
Try Robitussin :)
96GTS
Dyess AFB, TX
Mine does around this time each year. I think it's allergic to the pollen. :nana:
Detlef
Northern Colorado
It's normal once you add smooth tubes. The stock ribbed ones seem to prevent that whistling sound
red98RT10
Greenville, MS
I find that putting albuterol in the NOS system seems to help with the wheezing.
ViperTony
You guys are the best. :)
Purdue_Boiler_Viper
Indy
Add high flow cats and a good cat back. It'll still wheeze, but you'll never hear it.
Puntacanaviper
