Where to run nitrous lines on GTS?? Inside or out??
trainville
Oregon
I am getting ready to install the nitrous line from the trunk of my '98 GTS to the engine compartment. What is the best way to route the line?? I am hoping for a pre-existing tunnel so I don't have to run it under the car or through the passenger compartment.
Also, I just fabricated a 1/4" piece of plywood to fit perfectly in the trunk area. I covered it with black automotive carpet, and installed my bottle brackets to IT. It looks really clean and whenever I need the luggage space/etc, I just remove bottle, remove board and tuck lines away. I'll post a few pics of my progress if there's any interest.
TOOFST.....PM me the specs on your custom bracket. Thanks bro!
i cut a hole in the drivers side corner of the wheel well (trunk) and then up to the front thru the tunnel and up under the intake to the solenoid.
GTSnake
Motor City
That's almost exactly what I did. I ran it under the tunnel and zip tied it to the wiring harness lines on the driver side of the tunnel.
T
trainville
Oregon
What tunnel are you guys referring to, the center tranny tunnel, or another portion of the frame?
Carlos580
