which oil should be used on track for SRT-10 engine and gearbox?
Dan Cragin
LA, CA
If you do not have an aftermarket swing pickup oil pan, then I would run an oil that will give you some extra protection. Race oils like Motul 20-50w have a high Molybendium content that can resist bearing scuffing from a momentary loss of oil pressure.
I
ike
Germany
Thank you.
I already have a modified oil pan with baffles, otherwise I would buy the one with swing pickup.
Mobile1 15W50 is offered for motor bikes only in Germany. :dunno:
Does anybody know it is the same, or could we also use Castrol TWS 10W60 ?
Sorry for so many questions, but it is the first SRT-10 on track here and I do not want to kill it.
bluesrt
get some motul 15w 50 for cars. thats what i use- also motul for rear gear and transmission
Viperless
MN
Mobil 15w-50 in the engine and Motul Multi ATF in the trans.
