Which year vipers do not have a drain plug in the rear end?
SNKBYT
E.SWANZEY, NH
Is there any easy way to check the condition of the rear gear oil without removing the rearend? Didn't the earlier vipers have them? I seem to recall that my 95 had one.
ACR Joe
Newtown, PA
I do not believe any year came equipped with a drain plug. Your choices are to **** it out, or drill and tap the case to facilitate routine draining (I don't believe removing the carrier assembly is a realistic option). I chose the latter and had success drilling and tapping the case. As a result, I now have the ability to readily change the lubricant which many profess to be a critical maintenance issue on a Viper.
I acquired a flush fitting 1/8" plug from McMaster Carr; www.mcmaster.com or telephone them at 404.346.7000. The part number of the pipe plug is 4534K11.
good luck ......
Tom Sessions
Hampstead,NC.
The 92,93 and I think some early 94 carshad the drain plug factory install all these rears are the dana 44 and not the super 44 which is in the 96 and up cars
TacDoc
Catlettsburg, KY
Easy to vacuum drain. Go to WWW.overtons.com and get a device used to drain oil from boat blocks. About $39 for mine. I can change rear diff fluid in under 30 minutes now.
Greg
96 RT
00 GTS
Jerry Scott[CO]
Morrison, CO, USA
You will never get all of the metal particles out by sucking it out with a pump. I have a write-up with photos, for adding the drain plug and it is very easy. E-mail me and I will send it to you in a Word file.
Marv S
Scottsdale, AZ
Jerry, I think you should send it to [email protected] and have it included in the ILLUSTRATED UPGRADES Section.
http://www.viperclub.org/instructions/
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Jerry Scott[CO]:
You will never get all of the metal particles out by sucking it out with a pump. I have a write-up with photos, for adding the drain plug and it is very easy. E-mail me and I will send it to you in a Word file.<HR></BLOCKQUOTE>
Jerry Scott[CO]
Morrison, CO, USA
Marv - I posted it here a while back and Jay said that he was going to add it to "Illustrated Upgrades," but he never did. I'll send it again if he asked me for it.
