Who has dynoed their SRT10?
Brian E
Granger, Indiana, USA
I am looking for copys of A/F ratio dyno sheets from 03 and 04 SRT10's.
We ran 3 SRT10's on the Dynojet this weekend, 2 were stock and 1 was highly modified. The cars went way rich at WOT. ( 10.5-11.0 between 4400 rpm and 5800 rpm ) I am curious to see if this is a common occurence. Has anyone else encountered this, and if so what have you done to correct it?
Please e-mail or post your sheets. :2tu:
viper585
atl. ga
Mine pulled 10.0 at 5800,10.5 at 5000,11.0 at 4500.What were the H.P. and torque #'s for the cars?
Brian, please let us know what you discover.
As an aside, while I accept the relative values demontrated on the dyno Saturday across the 15 Vipers tested, I personally am VERY SKEPTICAL about the absolute numbers with regard to their accuracy, and therefore, meaning. I am NOT a fan of either "faith based" or "black box autocalibration" of these devices as touted by their operators. They are a great reference tool, but without frequent and careful 3rd party calibration and validation (using physical standards directly referencing to the Nat'l Institute of Technology...formerly Nat'l Bureau of Standards... or a similar entity) hardly an end-all authoritative validation of a given car's actual numbers...in MY opinion.
As there were many sad, disappointed faces leaving the dyno session...all planning to call the complaint line of the supplier of their latest upgrades... I would suggest that we remember Charlie's comment that went something like "Hey, Brother,Dodge has given us a car that will go 190 mph right out of the box...who cares what the dyno says !!!"
VIPER D
dutchess county, ny
I heard that mustang dyno's will give more accurate #'s due to real time load bearing.
turbo & sc cars have a hard spooling up on the dynojets
vd..
B
Brian E
Viper585, here is a copy of my A/F dyno sheet. Disregard the A/F dropoff at 2800 rpm, that was driver error, I blipped the throttle.
The stock 03 SRT10 was almost an exact duplicate of my A/F reading.
Steve, I understand the point you were making in your post. I am not concerned with the HP. and TQ. numbers as a whole. I did some quick calculations and it looked to me that as a group, we were down about 5% on our readings. I was a little surprised that our correction factor was at 1.0, this could explain lower than projected numbers. I also have to mention that the guys at Automotive Specialists did a great job taking care of our cars and running the event.
What I am seriuosly concerned about is that the SRT10 cars were no where near a 13/1 air fuel ratio at WOT. I have contacted a couple well respected tuners looking for advice. I will let everyone know what I discover. :2tu:
Casey
Valparaiso, IN.
If everyone was running rich, it could be the DYNO that was off! Seems odd that all the cars ran rich. :confused:
Ooomph
Rio Rancho, NM
I'm going to schedule my dyno for the end of the week. Problem is, is that I'm at 5300ft so there might be a larger correction factor. I will post-up as soon as I'm complete.
On a side note... On my C5 we could use LS1 edit to adjust a/f ratios, which is great for us guys at altitude. I'm new to the Vipers and wanted to know what it takes to adjust a/f ratios on these cars (specifically SRT-10's). Flash, chip, pcm tune? Any help would be greatly appreciated.
Ron
Indianapolis
Interestingly, since I have a port welded into my cats pre and post, we tested the A/F ratio both twice each. Will post later but found consistantly that the post cat A/F ratio ran 0.8 richer than pre cat. Odd...
Any ideas as to why?
B
Brian E
Ok, I had a very informative talk with Mark J. at Woodhouse today.
Mark let me know that the SRT10's that they have dynoed so far have the same A/F ratio as mine and the others we dynoed Saturday. He said this is typical for this car.
He also said that through tuning of the A/F ratio there is another 35-40 hp. and tq. to be gained.
Woodhouse has done a few of these cars and dyno tested them for real world results.
He also said that when they tune the cars they are shooting for a 12.8/1 A/F ratio at WOT.
Mark spent quite a while on the phone with me answering my questions. He is a very knowledgable guy and told me to call anytime I had a question. ( he seems to be cut from the same mold as Bill P. where does Bob W. find these guys....:)
It looks like the car will be on its way to Woodhouse for Bellangers, high flow cats, and the appropriate dyno tuning. :2tu:
Ps. anyone interested in a set of new generation Arrow cylinder heads for a SRT10 should give him a call, you might be pleasantly surprised at what he has to tell you.
FirecatF7
