Who has lowered their SRT?
Brian E
Granger, Indiana, USA
I need to get moving on deciding what shock, spring combo to use to lower my car.
The Motons look good, but real pricey. What other options are available? What have you guys used?
Manny what did you decide on?
:2tu:
Skip White
Kingsport TN
Aldan's have worked very well for me on several Vipers in the past. They are very adjustable, and of decent quality.
You can lower the car, front and rear, and adj. the compression and rebound.
If you have any questions about them give me a shout.
Skip White
Viperfreak2
Duncan, SC USA
Can someone explain the switchover process to Aldans? Can any competent alignment shop do the process without special tools and knowledge?
Skip White
Kingsport TN
The change over is very simple, at least the front ones are. The rear is something that you will want the alignment shop to do, as they will need to disconect one of the A-arms. They must have a spring comp. to remove the shock fork on the old shock. This is if you have an SRT.
Skip
sham5430
