Who has Roe Super charger Dyno numbers ?
Mike Adams
guelph, Ontario, Canada
I am interested in seeing some dyno number out thier I got mine runnig A1. Sean and I have found out some very interesting things about the viper. You would be amazed what a bad battery temp sensor.
Joe Dozzo
Golden, CO
I just dyno'd mine Monday. Best numbers from 4 pulls were 562 hp and 588 ft-lbs on car with headers, stock throttle bodies and stock cats. HP numbers ranged from 556 to 562.
Still needs a bit of tuning with VEC2 fuel and timing for my altitude (~6000 ft), but that's among the many values / benefits from the VEC2. In fact, new cards arrived yesterday (thanks for the great turnaround Sean) and testing continues in a couple of areas.
1TONY1
Dalton Ga. (Chatt. Tn.)
Please continue and tell us about the bad battery temp sensor. I am looking for gremlins myself.
SUN RA KAT
Guest
580.4 rwHP
607.6 rwTorque
70 mm throttle bodies, S&B filters, Roe smooth tubes, VEC2, Belanger Headers, Random Tech Ultra high Flow Cats, 3" Corsa cat Back, & 8.5 mm Magnacore spark plug wires. Stock rocker arms. Viper Race Yellow.
utahviper
Utah
I have a max of 697RWHP and 712RWTQ. I am hoping to solve my fuel problem(running out of fuel on the top end) and put out some real numbers. I am putting on a fuel pump and boost a pump to help with fuel delivery. I might have some results tomorrow but we will have to see if it rains.
Good luck on getting yours dynoed! 700++RWHP/TQ
Motor City Mad Man
Las Vegas, NV
Can you post the general overview of this battery temp sensor problem? I saw this temp sensor when I replaced my stock battery with a Optima red top and made sure the bettery temp sensor still contacted the new battery. Which it didn't when I first installed the new battery.
