Who has the best deal on shaft mounted roller rockers?
HOdbleFman
Hurricane, WV
I've noticed a lot of chatter in my valvetrain when I accelerate. I'm thinking this is due to the stock rocker arms. I'm looking for the best deal on a set of shaft mounted rocker arms if anyone knows where I can find them. I could be diagnosing the noise wrong, but it gives me a good excuse to add the rockers. :D Also, do I need longer pushrods if I go with the 1.7 ratio arms?
STUGOTS
NY/CT
with 1.7 u may have to change push rods most people do, they measure to see before you put the rockers on, the push rods are $120 at roe racing and if you want the best rocker arms i would get jesel j2k rockers from roe as well, they are the best from what i hear (better then t&d) and with tax and shipping they come to just under $1500 i just bought some and couldent be happier. Besides if there is any problem Sean Roe looks out for his customers
hope this helps
H
HOdbleFman
Hurricane, WV
I figure the Jessel rockers are the best, but I don't need the top of the line. I just want something with good quality and a low price. I figure I'll go with the T&D/Mopar based on what I've been reading. I just need to know where to get them at the absolute lowest price.
VIPER BAZ UK
ENGLAND
Installed the arrow ones this past weekend so far so good .......
Had it up and running but not been out for a long run yet typical English weather at the mo
Daniel Cragin/DC Performance Inc
Los Angeles, Ca
We have had good luck with all of the above mentioned rocker arms. If you install them correctly you should have no problems. I do have a set of Mopar T&D's at a close out price of $980.00. You wont find these for a better price.
J DAWG
MS
96 RT/10 (MIKE) I believe still has a brand new set of Mopar 1.7's for $850. As far as pushrods, the majority, but there are exceptions, use the 7.70's. Look on the Alley under classifieds to find the rockers for sale.
joe117
Maryland, USA
"noticed a lot of chatter in my valvetrain when I accelerate"
I don't see why the stock rockers would cause this noise. Do you think it might be a little pre-ignition knock instead?
You would likely get the knock when you accelerate if that's what it was.
sham5430
